Hi all, just trying to spec something up for a friend. His budget is around £600 and he will be using it mainly just for web browsing and other home computer stuff. He might be doing limited gaming on starcraft 2, left for dead 2 and borderlands 2 but this isnt certain.
I have come up with the 2 specs below. Tomshardware seems to generally recommend Intel CPUs over AMD so I am leaning towards that spec, plus its a bit cheaper. Will the standard CPU coolers hold up? Also, would being able to use the AMD crossfire ability between the CPU and the GPU make it more worthwhile going with the AMD set up (and would this motherboard support this)? I know I have done this on my rig but imagine it would make more of a difference at this lower end of the scale.
Many thanks,
PadForce
AMD BULLDOZER QUAD CORE FX-4170 (4.20GHz/4MB CACHE/AM3+)
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s, Windows 8 Ready!)
4GB SAMSUNG DUAL-DDR3 1333MHz (1 X 4GB)
1GB AMD RADEON™ HD7850 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Free Item
FREE SLEEPING DOGS GAME with AMD HD 7850 GPU & ABOVE!
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
STANDARD AMD CPU COOLER
Build time
Price: £615.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-bulldozer-top-spec-pc/3Podj9WKq4/
Intel® Core™i3-3220 Dual Core (3.30GHz, 3MB Cache) + HD Graphics
ASUS® P8H77-M: M-ATX, DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX™
Free Item
INTEL SOCKET LGA1155 STANDARD CPU COOLER
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Price: £597.00 including VAT and delivery. (+ £5 for silver, just spotted this!)
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-home-office-pc/tyR3K3xDaC/
Many thanks,
PadForce
Free Item
Build time
Free Item
