Budget of £400 - 500 for laptop
AESamuel
Hi there,
I have a budget of about 400-500 pounds to spend on a laptop. I know the basics of computer hardware but the in-depth stuff is lost on me so please bear with me when it comes to talking about hardware.
The laptop I want to buy will be used for general internet browsing, watching Films and some light/moderate gaming. Essentially I want a low-budget media laptop that can handle up-to-date games without having to scale the detail down so low as to take away from the gaming experience.
I'll list the three laptops I was thinking of getting and talk a bit about what I think of them and if you could offer any advice on where I could save money or improve the specs and help me decide between them then that would be much appreciated!
NOTE: I won't copy over the whole specs as anything I haven't modified will simply be left as standard - I am not interesting in adding more USB ports or getting a better sound card etc.
First:
Mirage: 13.3" Glossy HD LED Backlit Widescreen (1366x768)
AMD® Zacate™ E350 Dual-Core Processor (1.60GHz) 1MB L2 Cache
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 2GB)
AMD® Mobility Radeon™ HD 6310 - DirectX® 11, Shared Memory Architecture
Memory - Hard Disk
500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
£415 inc. VAT
Pros: The cheapest of my three choices. Portable. Budget allows me a decent sized hard-drive with options to upgrade.
Cons: Small screen may detract from films/games. Lack of customisation in terms of processor and ram. Lack of cd/dvd drive may be slightly annoying but using an external drive isn't much of a problem either.
This is certainly a possibility. I like the fact that it is cheaper but I'm just worried that it won't be able to handle the games that well.
Second and third are either the 14.1" Xenon or the Gensis III 15.6" both in glossy and both with the same specs so far.
Intel® Core™i5 Dual Core Mobile Processor i5-2430M (2.40GHz) 3MB
4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (1 x 4GB)
Intel® HD Graphics 3000 Video Memory Technology up to 1.7GB
Memory - Hard Disk
320GB WD SCORPIO BLACK WD3200BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
£496 inc VAT for the Xenon and £499.00 inc VAT for the Genesis
These laptops both have better specs than the mirage with options to upgrade the RAM to 8GB after I buy the laptop. The hard drive is slightly smaller but I have an upgraded processor. At the specs they are at the moment it seems like there isn't anything the Xenon has other the Genesis a mere £3 for the bigger screen. Or am I missing something?
If anyone has any comments/suggestions/improvements or anything really then they are very welcome!
Thanks,
Asa Samuel
Wozza63
Biblical Poster
be aware that those graphics wont get you anywhere with games
although over budget this should definitely do pretty good with games
Enigma III 540: 15.6" Matte HD LED Widescreen (1366x768)
Intel® Core™i3 Dual Core Mobile Processor i3-2330M (2.20GHz) 3MB
nVIDIA® GeForce® GT 540M - 2GB DDR3 Video RAM - DirectX® 11
Memory - Hard Disk
250GB WD SCORPIO BLACK WD2500BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
Integrated 3 in 1 Memory Card Reader (SD, MMC, MS)
Bluetooth & Wireless
ENIGMA GIGABIT LAN & WIRELESS 802.11N + BLUETOOTH 3.0
1 x USB 3.0 PORT + 2 x USB 2.0 PORTS AS STANDARD
Enigma III Series 6 Cell Lithium Ion Battery (5,100/5,200 mAh)
Power Lead & Adaptor
Notebook Mouse
INTEGRATED 1.3 MEGAPIXEL WEBCAM
Insurance
AESamuel
Thanks for clearing that up wozza365. My lack of experience when it comes to gaming technology is showing through. £30 over budget sounds ok, although I would swap the 250gb hard drive for the 320gb. Whenever I choose it in the dropdown menu the prices are the same so I may as well up the memory for no price difference.
Is there much difference between the I3 and the I5 processors? I know it is 2.20ghz and 2.40ghz but are there any other differences?
Thanks!
Wozza63
Biblical Poster
there is a difference although i think the price increase is quite a bit, probably not worth it on a low budget
Neil Grey
Also, if I where you I'd up the CPU if possible, 1.6GHz isn't great in a quad-core setup, let alone a dual core one.
