Ratbone
Hi All,
After being plagued by Blue Screen of Death since delivery and one RMA later (thinking it was a hardware issue) with a persistantly blue screening system I started researching the problem on the net.
And I'm happy to say I have found and fixed the issue..... IT is the OCZ Vertex 3 SSD which is the culprit.
The latest OCZ Hard drives come with firmware version 2.11 (at least up to 3 weeks ago when my system was delivered). There is a bug in that version of firmware which according to the release notes of Firmware version 2.15 says:
RELEASE NOTES:
Issues resolved since version 2.13:
Fixed a rare condition that may cause Windows Blue Screen error when the primary configured drive woke up from either a SATA slumber mode or S3/S4 modes
Fixed a rare condition that may cause Windows Blue Screen error when the drive was
configured as primary with OS installed
Fixed a corner-case issue that may cause the drive to stutter or Windows freezing screen
when a media read error occurred
Further improved robustness of Secure Erase operation to prevent possible low-level data
structure corruption
Significantly improved TRIM handling to enhance system stability.
Whoever has an OCZ Vertex Drive will need to go to the download website:
http://www.ocztechnology.com/ssd_tools/OCZ_Vertex_3,_Vertex_3_Max_IOPS,_Agility_3,_Solid_3,_RevoDrive_3_and_RevoDrive_3_X2/
and download the Toolbox to upgrade the firmware AND PLEASE READ the instructions:
WARNING: If the OCZ drive is the Primary OS drive then the Firmware Upgrade will not work. No problem there is a bit of workaround to do.
This is how I did it:
Since I have a secondary D: drive (1Tb), I installed Windows 7 on it as well and then installed the Hardware drivers (Network drivers are the only ones needed for the SSD firmware upgrade since internet access is required for the firmware download.
The system now became a dual boot Windows 7 system. I booted on the D: drive and change the Drive letter on the C: drive to G: to fool the Toolbox in thinking it is not a Primary OS drive. I ran the Toolbox (as per instructions) and upgraded the firmware to version 2.15.
I then changed the drive letter of the SSD drive back to C: and then rebooted back to the Primary C: drive OS.
My system is now a dual boot system and Hurrah!!! the BSOD is past tense.
With regards managing the Dual Boot Menu I used BCDEDIT command line.
http://www.sevenforums.com/tutorials/2676-bcdedit-how-use.html
RELEASE NOTES:
