Boot up issues
rouchie
Rising Star
Hi all, I am only day 36 on my 3080 build so still need my current PC functioning for a little while longer! I am having issues pretty much everytime I boot now, where it hangs with no actvity, and then I press reset and it boots perfectly? Any ideas what might be the issue here? Its not a PCS build but it needs to last until U get my new PCS build!
System info looks like this with a GeForce 970 GTX
Sorry, but we can't advise on non PCS builds, even if you're in the process of waiting for one, I realise that's annoying.
You may want to check out Toms Hardware which is an open forum, they're excellent and will definitely help you out.
I would suggest a clean windows install as a start to verify it's not software related.
