You're going to need to elaborate here - what did you do? Swap out a secondary drive for a larger one? Swap out your main hard drive for a larger one?
If you put the windows DVD in then the PC will likely boot from that regardless - but there will be a boot from DVD option in your bios - is that where you are looking?
You need to disable uefi secure boot in the bios, then adjust the boot order.
I read the post a few times but not once did i see UEFI before each option. I'm going to get back in my box now![]()
Silly question alert - do you have a DVD drive?
I'd probably give PCS a call just now to discuss, is there not space for both SSD's in the laptop?
Failing any other options, you should be able to download it from another device and transfer it over using a usb pen drive (or similar)
