After installing my wonderful new Samsung 850 pro SSD I had a very difficult time installing Windows 8 on to it.
After half a day I managed to get Windows successfully installed (I wanted a fresh install rather than use an image).
The situation I have now is that if I select the Samsung drive as boot priority I get a boot error and boot does not happen.
However, if I have a disc in the disc drive (it can be any bootable disc) and select the optical drive as boot priority, I will get the press any key to start disc message, and if I leave that the boot continues as normal and the boot is successful.
The boot options in Windows shows two Windows 8.1 but I've tried setting both as the boot OS and I still can't boot directly from the Samsung. I've tried EasyBCD boot manager and added a new boot option pointing to the Samsung C drive, and that does not solve the issue either.
The only boot options in Bios are the ATAPI drive or the Samsung.
Any suggestions?
On another note I've installed 8GB more RAM to make use of Samsung RAPID (which since enabling shows in Crsytal Disk Mark a read speed of 7918 when before it was 526).
When I first tried to boot I got a quick fail with the message that my overclock (which I set when I got the PC) did not work. I've backed the OC off a bit and so far so good (I've done a stress test). Is this some kind of CPU power issue?
Any suggestions?
