Hello All,
I need some debugging for my defiance III brought back in 2016.
Following Specs:
Defiance Series: 17.3" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™ i7 Quad Core Processor 6700HQ (2.6GHz, 3.5GHz Turbo)
16GB HyperX IMPACT 2133MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
1st Hard Disk
750GB WD BLACK 2.5" WD7500BPKX, SATA 6 Gb/s, 16MB CACHE (7200 rpm)
Partitions: 500GB, 250GB
240GB KINGSTON SSDNow M.2 2280 G2, SATA 6Gb/s (550MB/R, 330MB/W)
Partitions: 100GB, 140GB
I have several issues that I can't for the life of me work out what the root cause is:
1) excessive heat build up noticeable through the keyboard. I've clocked temps around the 75-90 range when under heavy load. which eventually result in a heat crash. I've tried to clean the fans but no change (took a compressed air can to it and spray around the fans and electronics).
2) random shutdowns that do not cause an error when plugged into a mains supply.
3) The laptop gets what I can only describe as stuck in a boot cycle. It will power on every shot, but windows for whatever reason will get stuck at the various stages of booting up. This could be just a black screen, or the starting up screen or it could complete those and get stuck at a blank screen before the log in screen.
I am running windows 10 for reference.
My gut tells me for option 1 I probably need to get it repasted, for option 2 I've no idea what to do and lastly for option 3 I'm thinking I need to do a back up and then a clean install of windows/factory reset.
Anyone else have any thoughts or suggestions for all three?
Following Specs:
1st Hard Disk
