Bluetooth & Wireless
_Francesco_
GIGABIT LAN & WIRELESS N
WIRELESS 802.11N CARD INC. BLUETOOTH
ONBOARD GIGABIT LAN & INTEL ULTIMATE-N 6300
KILLER™ 1102 WIRELESS 802.11n CARD
In lay terms, are there any significance differences between the options? What is the 'typical' choice?
Thanks.
Teaz
No, the higher options just accepts higher Mbps. good for people that use higher/faster speed connetions.
The killer is different as it focuses the connection on gaming during gaming mode.
jacobpov
No, It also has faster transfer and better latency speeds
Teaz
thats why i said 'Mbps' as a quick short answer.
If you wish to explain in depth the do as you will :)
