Issue now solved also P.S a little advice to anyone who knows nothing about Pcs look a little more at the manual even if the diagrams are a bit different to yours. My issue was that I had plugged my monitor wire in the wrong section only took a bit of cable management to figure that out lol.
Recently my Pc has begun bleeping when turned on. One long bleep followed by multiple bleeps and the first time it happened my monitor screen went dark now my monitor works but i still get those bleeps at start up. I don't know why but looking at the forums it means I have an issue any helps appreciated. Edit: context i bought it almost 2yrs ago and idk anything about pcs but here's my specs.
PCS SPECTRUM RGB MID TOWER CASE (WHITE/PINK)
Intel® Core™ i5 Six Core Processor i5-12400 (2.5GHz) 18MB Cache
GIGABYTE B760 DS3H DDR4 (LGA1700, DDR4, USB 3.2) - ARGB Ready!
16GB PCS PRO DDR4 3200MHz (2 x 8GB)
Graphics Card Support Bracket
NONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti AND ABOVE)
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
2nd M.2 SSD Drive
NOT REQUIRED
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
ONBOARD LAN PORT
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Monitor
PCS BD24 23.8" IPS Monitor - 1080p, 5MS, 60Hz
2nd M.2 SSD Drive
NOT REQUIRED
ONBOARD LAN PORT
Monitor
