blackmagic
ClaytonJoness
would i be able to use a blackmagic intensity suttle with this:
AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
1GB ATI RADEON™ HD5450 - DVI,HDMI,VGA - DirectX® 11
2nd Graphics Card
NONE
NONE
RAID
NONE
2nd DVD/BLU-RAY Drive
NONE
NONE
STANDARD AMD CPU COOLER
2 PORT USB 3.0 INTERNAL PCI EXPRESS CARD
Modem
NONE, I WILL BE USING BROADBAND
Nemesis
I am led to believe that the blackmagic intensity shuttle is a USB 3.0 device and your motherboard is only USB 2.0 so either youd have to buy a USB 3.0 PCI expansion card or upgrade your motherboard to one that does support USB 3.0
Also might i reccomend that you add the silver warranty to your spec which, for only a fiver, adds 11 months of PCS paid for collect and return
(this means that, in the event of a problem arising with your computer, PCS will pay for the postage of your computer for repair to and from their center)
EDIT* : Ignore what i wrote here a sec ago, i misread, the shuttle means that it is the USB 3.0 version doesnt it (my bad)
