Hi All,
I hope someone on these forums may have some better suggestions than the web.
I have tried searching this and there's many threads however I've not found any that seems to help much so looking for some further suggestions/help from people with better technical knowledge.
ProblemMy wife has a PCS desktop machine (spec below), approx 2 years old now running Windows 7 Home Premium 64 Bit.
It's a general use machine, no gaming or anything fancy, mainly emails, Word docs, Excel, Powerpoint, web browsering, You Tube, iTunes, some video playback, etc....
For the last 3 months or so when the machine starts/boots... it "hangs" with a Black screen and the windows cursor "pointer" only thing on screen --- also other thing is a intermittent flash from HDD light.
NOTE : This does not happen every time the PC boots, but at least once in 10 starts (sometimes more frequent)
To resolve this, is to power off (hold powerbutton for few secs to power down) and then power on again......
'Normally' windows then starts but trys to do a system repair which can take 5-10mins and sometimes does a Restore......
This generally resolves things, however sometimes we have to repeat this power down/start process a couple of times.....
Once's it's recovered it normally starts Windows and is fine, so obviously there's not something fundamental wrong with the PC, however it's getting to be a pain.
I cannot exactly pin point when this issue started and there's been no changes to the PC in terms of hardware upgrades. Some software has been added over time but generally these are standard packages.....
I'm reasonaly tech savvey and have looked at threads on the internet to "update" drivers, as one possible solution --- I'm not really too sure if this is a recommened route so have not tried this yet ??
Any advise/suggestions tips, if someone could suggest I'd really like to hear please ?
It's getting to the point where I'm thinking of re-installing Win7 or possibly even upgrading to Win8 to see if this will solve the issue, however I need to be careful about the data on the PC.
It is networked via homeplugs to the Router and we do have a NAS storage device on the Router so I can make backups.....
Please help !
Thanks,
Brian
Processor (CPU) Intel® Corei5-650 Dual Core (3.20GHz, 4MB Cache) + HD Graphics + Turbo Boost
Motherboard INTEL® DH57JG: H57 Express Chipset, 10-Channel HD Audio, 2x DDR3
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB NVIDIA GEFORCE GT430 PCI EXPRESS - DirectX® 11
2nd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
1st DVD/BLU-RAY Drive SONY BD-5730S 6x BLURAY WRITER & CYBERLINK SOFTWARE (£119)
Memory Card Reader NONE
Sound Card ONBOARD 10 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options 8 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Bluetooth & Infrared Options NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Office Software FREE Microsoft® Office Starter 2010 (Limited functionality Word & Excel)
Monitor NONE
2nd Monitor NONE
DVI-D & HDMI Monitor Cables NONE
DVI-D & HDMI Monitor Cables NONE 1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£8)
Please help !
Thanks,
Brian
Monitor NONE
2nd Monitor NONE
