Black screen but computer running?
radhumble
Hi all!
I received my PC from PCS about 4 months ago and I couldn't be happier. However, very rarely, my computer will almost faux shut off. My monitors will go completely black, my peripherals lights will turn off, but my computer will stay on. When prompted to turn off with the power button, or restart button it's unresponsive.
It's very strange, and it happened to my last computer so I'm not really sure what to make of it. Is it my computer or my power?
Anyone had any similar experiences?
Thanks in advance for the replies!
Can you post your full specs from the order please so that everyone can see what build we're talking about?
That the same thing happened with a different PC does rather suggest that it's something environmental and not with the PC itself. It could well be the power.
If you're using a surge protector extension (and you should be) then replace it with a new one. That would be my first suspect.
radhumble
CaseCORSAIR CARBIDE SERIES™ 275Q QUIET CASE
Change to: FRACTAL DEFINE 7 BLACK QUIET MID-TOWER CASE
Processor (CPU)AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
Change to: ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB)
Change to: 16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
Change to: 8GB NVIDIA GEFORCE RTX 2060 SUPER - HDMI, DP - VR Ready!
1st Storage Drive1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (up to 550MB/sR | 520MB/sW)
Change to: NOT REQUIRED
1st M.2 SSD DriveNONE
Change to: 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingNoctua NH-U14S Ultra Quiet Performance CPU Cooler
Change to: Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
BrowserGoogle Chrome™
Monitor CablesNONE
Change to: 1 x 2m DisplayPort Cable - DP (M) to DP (M)
Change to: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
