i want to get it down to around £1k all in and its to be used for everyday and quality gaming.
i dont want to find in a years time i cant upgrade some bits so any helpful unbiased help much appreciated
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Intel® Core™i7 Quad Core Processor i7-960 (3.20GHz) 4.8GTs/8MB Cache
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£45)
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£86)
INTEL SOCKET LGA1366 STANDARD CPU COOLER
