skipper8472
If i ever did buy parts for a new PC instead of buying one already built and confugured. When you buy motherboards on there own and not been configured do you have to do it your self and also depending on what PSU you got would you have to alter the power settings etc. Or would it be ok just run and not bother with the bios?.
Would you have to put the correct voltage in the bios for a certain PSU wattage?. Say you got a 750wat PSU would you have to set the bios right for that wattage and same if you got a 1000wat PSu you would have to set it right in the bios for that?.
