Rhiannon_B
Hi, I’m hoping somebody will be able to help me narrow down a problem.
Quite a while ago, my desktop (bought from here in 2022) turned off unexpectedly in the middle of a windows update. It would then only open BIOS when I turned it on and sometimes under Boot Priority it would say “Windows Boot Manager (M.2_1: Samsung SSD 970 EVO Plus 1TB) (1000.2GB) and sometimes it was blank. I tried reinstalling windows, but it wouldn’t recognise the drive and on the few occasions it did, it said it can’t write to any of the partitions.
I tried to contact a repair technician and they said they didn’t repair custom gaming PCs unless they built them themselves, so I thought I’d try myself.
My guess is that I need to buy a new M.2 SSD Drive but it looks like a tricky thing to locate and replace. Before I go trying to work out where it is and how to do it, is there anything I should try first? I tried to replace the 1st storage drive (on the off chance) as that looked a lot easier to replace, but unsurprisingly it didn’t do anything to help.
Specs:
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
Specs:
