Vortex 3.
Dual 7970m's.
Paid for Thermal compound.
Using zalmtec cooler.
Ran Furmark Benchmark
About 20% into said Benchmrk
GPU1: Max Degrees 77oC
GPU2: Max Degrees: 96oC
I shut it off as 96 was a bit worrying to me.
Question: Is it normal for the temperature to get that high and is it normal for a 20 Degree difference between GPU's?
Any advice. Thx.
Dual 7970m's.
Any advice. Thx.
