I've had disagreements with others on here before about using msconfig to permanently disable startup programs. Microsoft recommend that msconfig is not used to do so, it's only a temporary debugging tool, and that is the position I have always taken. Others on here (and elsewhere) have disagreed with me citing their experiences of using it over the years to permanently disable startup programs with no apparent problems.
Well msconfig has just bitten me, so here's why it's not safe to use it for permanently disabling startup programs.....
I've been doing a factory restore on an HP Pavilion laptop for a friend, these things always comes with stacks of bloatware of course so as part of the factory restore I decided to uninstall the bloatware he didn't need. Immediately after the factory restore I started to get pop-ups from Norton asking to activate the included Norton Security and Norton Online backup software (no thanks). As a workaround before I got round to uninstalling them I disabled them from starting in msconfig to stop the annoying pop ups at every reboot. After a mornings work installing almost 200 Windows updates, copying his user data back and reinstalling all his third party programs I finally got around (as part of the clean up at the end) to uninstalling the bloatware he didn't need (including the two Norton products). The laptop was booting real fast and performing very well before my final clean up, but after it the laptop took an age to boot, disk activity was frantic and even after logon it took an age to get to the desktop.
That's when I realised my error of uninstalling a product (two actually) that were disabled from starting up via msconfig. I rather think the disk thrashing on boot was Windows searching for the disabled (and now uninstalled) programs. Rather than bumble around trying to sort the problem I decided to start again and do another factory reset. This time I left msconfig well alone and uninstalled the two Norton products straight away. The laptop is now performing beautifully.
So, despite the apparent experience of many, it is not safe to use msconfig to permanently disable programs from starting. So there!
