Get a 256gb PM961 or SM961 M.2 NVMe PCIe SSD. You can look up the various acronyms if you like but in real terms they're just SSDs that are a lot faster than other models while being not very much more expensive at all, especially at the 256gb level.* What I need advice about:
HDD_1 - fast boot storage, 256gb but: do I want m.2? SSD? PCIe? (I am currently confused by those terms)
I don't think the chassis is older to any meaningful degree, and I don't see any other inherent implications. Just check that the chassis supports any features you need. (e.g. How many USB ports do you want? Do you need TPM? etc).I am just wondering, since this laptop supports only up to 2133, does that mean the mobo is older? What other implication there may be for going with this seemingly older chassis/mobo?
It is, they say on the main laptops menu page - if you know that S-Series means Desktop CPU and H-Series means mobile CPU (not many people will in fairness...)I am shocked that it's not immediately obvious in the configurator!!!
What newer components? I think you're reading far, far, far too much into the RAM frequency thing if it's that...supports newer components
Didn't you say you were going to use the laptop screen down 99% of the time? Hardly seems worth £200 for a 120hz screen that's only getting used 1% of the time.120hz screen...
Why?Also, the Proteus V power supply at 200 watts looks extremely suspicious, compared to Defiance 150 watts (which is suspicious in itself!)
The power consumption is specified with a TGP of 80 Watt and therefore slightly below the old GTX 970M. Since summer 2017 a low power variant (Max-Q) is available for thin and light laptops with reduced performance and a lower TGP of 60 - 70 Watt.
https://www.notebookcheck.net/Mobil...060-Laptop-Benchmarks-and-Specs.169547.0.html
