Basic spec. but just need it to be checked
MicMed
Hi ,
I'm replacing my PC - originally obtained from PC Specialist as it is now six years old and is starting to wobble.
I'm a basic user - not at all teccy - and use my PC for spreedsheets and word docs, web browsing and also as a hub for downloaded music files which I cast to a media unit. I also watch You Tube videos. I also burn Bluray and DVDs occasionally.
I've chosed a SS drive and a standard drive.
I'm really not sure about eithier the processor or graphics card - if they work together or if they will meet my needs.
I'm also not sure if I need to replace my monitor a Iyama ProLite E2208HDS which is also quite old but working well.
Do I need to add an additional fan with the three drives?
My spec:--
PCS 3601 CASE
AMD Ryzen 5 3350G Quad Core CPU with Radeon Graphics (3.6GHz-4.0GHz/6MB CACHE/AM4)
GIGABYTE GA-A320M-S2H: Micro-ATX, AM4, USB 3.1, 6GB/s
8GB Corsair VENGEANCE DDR4 2666MHz (2 x 4GB)
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
8TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & SOFTWARE
PCS 250W 80+ BRONZE POWER SUPPLY
STANDARD AMD CPU COOLER
Firefox™
LOGITECH® K120 USB KEYBOARD
Miscellaneous
Created Using Jargon Free Configurator
Welcome Book
Price: £862.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-home-office/JpfuH9Jybq/
I have a budget of about £1k. Any advice or tips would be very welcome.
Thanks,
Mike
I think this may be a better spec for longevity. Much more up to date processor, higher frequency memory and a quality power supply that won’t be whirring away noisily under your desk. I’d also steer clear of the HDDs over 3TB capacity as the write speed drops to a painfully slow 5400RPM.
FRACTAL FOCUS G BLACK GAMING CASE (Window)
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4)
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
Firefox™
Price: £1,000.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/WeAwx8bPPe/
What are the specs of your current PC? My guess would be that you could simply reformat Windows or perhaps install an SSD to get a performance boost. I would be surprised if the PC you have is at end of life.
MicMed
My current spec is:-
Processor Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.20 GHz
Installed RAM 8.00 GB
Samsung SSD 860 EVO 500gb
ST4000DMOOO 4tb
System type 64-bit operating system, x64-based processor
Having recently researched the Seagate i noticed it is more prone to failure than others in the ST range - I'm probably lucky it lasted so long.
