Hi All
I recently received a Nova 15 from PCS with a 1TB PCS NVMe drive however it looks like I may have got a bad drive, which seems a pretty slim chance these days I know but I have done all I can think of with it. Note this drive is to be used as a non-OS drive. I have my OS on a Samsung 970 EVO which is working fine
On receiving the machine (No OS option), I formatted the drive using partition wizard. This failed halfway through to the point where the drive was no longer picked up by PW or in the bios. I reseated it just to check that was ok and it was then picked up again by the bios and PW. I managed to do a quick format with a single NTFS partition which appeared to work ok until I noticed the drive was write protected in Windows. Used disk part to Remove the write protection attribute and used the clean command. Again this caused the drive to disappear on Windows and not show either on explorer or disk management.
As a last attempt I used PW again but as bootable media and managed to reformat the drive. This again appeared to work until I tried to restore data to the drive and it failed halfway through. It seems anytime there is prolonged writing to the drive it dies.
I’ve ran a surface test on the drive and no bad sectors reported. All chipset drivers are up to date from the PCS downloads section. Should I contact PCS to get a replacement drive sent out? Config-
Nova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Nova Series Detachable 4 Cell Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
15" NOVA SERIES UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
INTEGRATED 1MP HD WEBCAM
Promotional Item
Get Assassin’s Creed® Valhalla with select AMD Ryzen CPUs
Welcome Book
AC Adaptor
1 x 230W AC Adaptor
Promotional Item
Welcome Book
