Awaiting Optimus II 15.6"!
EliseRobinson
Here's the config I've just ordered:
Chassis & Display Optimus II: 15.6" Glossy Full HD LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™i7 Quad Core Mobile Processor i7-2630QM (2.00GHz) 6MB Cache
Memory (RAM) 8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
Graphics Card nVIDIA® GeForce® GT 555M - 2GB DDR3 Video RAM - DirectX® 11
Hard Disk 500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
The rest are standard specs:
DVD Drive 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Network Facilities GIGABIT LAN & WIRELESS 802.11N CARD INC. BLUETOOTH 3.0
Battery Optimus Series 6 Cell Lithium-ION Battery - 48.85WH
Windows 7 Home Premium 64 Bit
Integrated 1.3 megapixel webcam
Price £784.00
What do you think? Very very excited! Will post pictures and a review after I've had a chance to use it for a little while.
It's going to be used for moderate gaming and graphic design. Did I mention I'm VERY excited? :D
njmarkham
very nice, price is good too. I'm looking to order the same, but 17" and agility 3 120gb ssd. When are you expecting to get it?
EliseRobinson
It's on it's second working day and on pre-production, so really anything from 5 to 10 working days time. I'll re-post here when I've got it. I would have loved a SSD but couldn't afford one and I only chose the 15" so it would fit in my rucksack - I have to cycle to university. :(
Corfate
I found that doing that made me depressed.. Not seeing it moving until the 7th working day, then it all got kicked into motion ;)
EliseRobinson
Can't quite believe it - laptop has been dispatched and this is the 4th working day.
There can't have been the 24-48 hour testing period in this time. Not that I'm complaining about super fast service!
Does the testing not need to be done for as long on laptops? I feel stupid asking such a simple question, but I'm confused and delighted at the same time!
Flatsix
Jup, mine got dispatched at the end of 4th working day as well.
Hope Carl Auckland has done proper testing regarding this.
dairees
Nicked from the order status guide:
If your order status says In Quality Control, this means that your order has been tested and is now in our "hot room" where the system will remain for at least 24 - 48 hours (2 - 48 hours for laptops) until we are satisfied that the system has passed our quality and performance checks. The "hot room" ensures the components in your system are "burned in" and that the system performs correctly before dispatch.
No idea why laptops can be tested over a shorter period but it looks like they are
EliseRobinson
Darn brackets distracting me from relevant information! Thank you!
