Awaiting Dispatch....
TheFAQqer
COOLERMASTER CM690 MKII ADVANCED CASE
AMD PHENOM II X6 1100T (3.30GHz/9MB CACHE) ***SPECIAL OFFER***
ASUS® M4A89TD PRO/USB3 : DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX
16GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (4 X 4GB)
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£89)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£49)
Firewire & Video Editing
3 Port IEEE 1394a Firewire PCI Card (£9)
FAST TRACK 3 WORKING DAY DISPATCH (£59)
So tomorrows task is to remove the graphics card from this machine and put it in the new one.
And install Windows.
And install Linux.
And install the additional hard drives that I'm taking out of this machine and put them in the new one. And start installing software so I can start work.
And then rebuild the old machine so it can go to a good home.
Looks like a long day coming :D
Gorman
The rig will most likely come with a test install of windows on the drive and the controller set to AHCI.
Just as a heads up.
Rakk
The Awesome
And if you have a fiver to spare I suggest upping your warranty to silver, just for more peace of mind :)
