Awaiting build!
KarenClayton23
Hi all, I'm eagerly awaiting delivery of this. Opinions? I cannot have a pc due to space, my home is a tiny house under 300sqft! so no room for a desk area at all. I do have a cooling plate if heating is a concern. Apologies if this is a duplicate post, I posted yesterday but cannot find my post anywhere! Browser is set to edge only because OperaGX was not an option. I plan to store all my games on the 4tb drive.
Recoil Series: 18" Matte UHD+ 200Hz DCI-P3 100% LED Widescreen (3840x2400)
Intel® Core™ Ultra 9 24 Core Processor 275HX (Up to 5.4 GHz) 36MB Cache
64GB Corsair 4000MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 5090 - 24GB GDDR7 Video RAM - DirectX® 12.2
2nd M.2 SSD Drive
3rd M.2 SSD Drive
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
AC Adaptor
1 x 330W AC Adaptor
Recoil Series Integrated 98WH Lithium Ion Battery
4.1 High Def. Audio + Sound Blaster ™ Studio PRO 2
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® Tri-Band Wi-Fi 7 BE200 + BT 5.3
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
RECOIL 18 SERIES RGB BACKLIT UK KEYBOARD
Change to: Windows 11 Professional 64 Bit - inc. Single Licence
Microsoft® Edge
Notebook Mouse
INTEGRATED IR+FHD Hybrid Webcam
Welcome Book
PCSpecialist Welcome Book
steaky360
Hi, if you would like some feedback it would be helpful if you can post your specs in an easier to read format.
Best way to do that is to check your login to the main PCS website (its different to the forum account) and go into your orders and copy/paste the specs from there.
Some guides (including how to best post your spec) and commonly asked questions are here: https://www.pcspecialist.co.uk/foru...posting-collaboration-of-helpful-hints.77691/
I can't find any other posts against your username so unless you've created a second account by mistake this is the only one I can see.
Ekans2011
Considering and presuming that the system's main purpose is gaming, I'd go with the Recoil AMD, because the 9955HX3D would improve gaming performance with the 3D V-Cache.
Furthermore, the Recoil AMD will have a liquid cooler available (+£131), which is required to avoid thermal throttling.
Recoil Series: 16" Mini-LED QHD+ 300Hz, 1250nits, DCI-P3 100% (2560x1600)
AMD Ryzen™ 9 9955HX3D 16 Core Processor (2.5GHz, 5.4GHz Turbo,)
32GB Corsair 5600MHz SODIMM DDR5 (2 x 16GB)
1TB CORSAIR ELITE MP600 NVMe PCIe M.2 SSD (up to 7000 MB/R, 6200 MB/W)
AC Adaptor
1 x 420W AC Adaptor
Recoil Series Integrated 99WH Lithium Ion Battery
PHASE CHANGE THERMAL PAD COOLING (PTM7950)
GIGABIT LAN & WIRELESS AMD Wi-Fi 6E AW-XB591N (2.4 Gbps) + BT 5.2
2 x USB 3.2 PORTS (Type C) + 3 x USB 3.2 PORTS
RECOIL 16 SERIES RGB BACKLIT UK KEYBOARD
Firefox™
Dead Pixel Guarantee
Chassis
AIstone X6FR559Y (24GB RTX-5090, R9-9955HX3D, 300Hz QHD+ Mini-LED, RZ616)
Price: £3,260.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-16-AMD/an8Vftj3EZ/
KarenClayton23
Thankyou, Ill edit post with copy and paste.
AC Adaptor
1 x 420W AC Adaptor
Firefox™
Chassis
AC Adaptor
1 x 420W AC Adaptor
Firefox™
Chassis
Hi, thanks for your input. The 18" recoil does not have the option for the AMD CPU (hope i got that right I'm sort of learning as I go!). I do have a Llano cooling pad with a turbo fan, which I had hoped would avoid thermal throttling? again apologies if i have the terminology wrong still learning at 53 lol.
Ekans2011
The 18" chassis is from a different manufacturer (Clevo), and there is currently no AMD choice.
I don't believe any cooling stand can avoid thermal throttling on new laptops/DTRs; it's an outdated technology that's essentially worthless.
Unless Clevo's PLs are reduced, it will experience thermal throttling without an appropriate cooling solution.
Ekans2011
I honestly have no idea why the 18" Recoil doesn't come with the cooler option...frankly, all Recoils should come with a mandatory cooler, especially at the top end of specs
Probably because Clevo manufactures the Recoil 18'' whereas TongFang manufactures the 16'' model.
The latter manufacturer has always prioritised maximum performance above build quality (though this was mostly in the past), whereas Clevo has the opposite policy: build quality over maximum performance.
I can't think of another reason why the 18' chassis doesn't have an external cooler.
