ok ive got a big problem that im not sure how to fix.
Games run fine on this system it would appear however ive only tested skyrim/diablo3/sc2 on the highest settings. This program however when moving around a 3D object is very laggy to the point the program can not be used.
ive got a 3Vortex Series:17.3" AUO Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3720QM (2.60GHz) 6MB
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
NVIDIA® GeForce® GTX 680M - 4.0GB DDR5 Video RAM - DirectX® 11
Genuine Windows 7 Home Premium 64 Bit w/SP1
my 3dmark 11 score on this is so bad http://3dmark.com/3dm11/4041045 and windows has my card at 7.1 rating so any advice would be great on how to get this running normal.
PS it will work with no lag on a amd athlon dual core 2ghz with 2gb of ddr2 low speed cheapo ram with an old radeon hd 4850 512mb ddr3 Genuine Windows 7 Home Premium 64 Bit w/SP1 as this was what i used.
if you need anymore info just holla.
