Hello.
I have been browsing PC specialist for a good few months as i do as much research as possible before i upgrade my system.
I am planning to build a pc primarily for Professional Audio production. I know here they are tailor made to be a gaming laptops but the specs are essentially the same if not more demanding in every area except gpu.
I like the idea of being relatively mobile but having the same power as a tower system.
This is the laptop specification i have had my eye on:
Chassis & DisplayOctane Series: 17.3" Matte 4K IPS LED Widescreen (3840x2160) (No G-Sync)
Processor (CPU)Intel® Core™i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
Memory (RAM)32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® GTX 1060 OC 1480 MHz - 6.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk 500GB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk 1TB SERIAL ATA III 2.5" HARD DRIVE WITH 32MB CACHE (7,200rpm)
M.2 SSD Drive 1TB SAMSUNG SM961 M.2, PCIe NVMe (up to 3200MB/R, 1800MB/W)
Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)AC Adaptor1 x 330W AC AdaptorPower Cable1 x 1 Metre UK Power Cable (Kettle Lead)
Thermal Paste: the better one (£9) accidentally copy and pasted the standard option
Sound CardIntel 2 Channel High Definition Audio + MIC/Headphone JackBluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0, vPROUSB Options
4 x USB 3.0 Ports + 2 x USB 3.1 Type C Ports
my main issue is Temperature concern. i know the octane has an advanced fan system but i would really appreciate some estimates on heat output. i would also be willing to underclock the GPU (not the cpu) if that can bring it down. Would this laptop be safe and cool enough to last me 3/4 years? Would this rig remain cool enough under pressure of Music audio workstations (if anyone has that knowledge)? or is it safer to forget mobility and get a tower solution. How different would a tower be with lets say a corsair h100i v2.
Thankyou all.
Thankyou all.
