Asus® m4a87td or asus® m4a78lt-m
I3astards
is there much point getting ASUS® M4A87TD ??? Im getting a Phenom ii x4 970 and GTX 460 for gaming. what the differences??
misterdave
I'd go with the M4A87TD purely because it has a better chipset and is not a microATX motherboard. I always try to avoid MATX motherboard unless its for a small home office system as you can never be too sure what they cut out when making a smaller board. Though the case might limit you to a 78LT-M.
What case are you going with?
I3astards
Thats helpful info to know... The case Im going for is Coolermaster 310, will that be OK M4A87TD mobo??? Will there be much difference in performance between the two boards??
misterdave
The case is fine for both as its an ATX sized case.
Not that you'd notice but purely on personal preference I'd go with the M4A87TD. Plus there is the added USB3 on board backwards compatible for now, but when more USB3 devices are available it will be great.
