Are the ports on the top USB2 or USB3? (feeling dumb)
David689
Feeling dumb here but I have gathered up the courage to ask. I bought the system below about a year ago. I have only used the USB ports on the back of the machine, for keyboard, mouse and external drives and a card reader. I can identify USB2 vs USB3 here by the usual colour convention ie blue is USB3 and also by consulting the motherboard manual. But there are two two USB ports on the top of the case - can I identify whether these are USB2 or USB3, without tracing the connectors to the motherboard? and if so, how, please.
Thank you.
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
64GB Corsair VENGEANCE DDR4 3200MHz (4 x 16GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP, LHR
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
B4zookaw
Corsair's spec says "(1x) USB 3.1 Type C, (1x) USB 3.0," Not sure the MB supports the type C though:
"4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
1 x USB 3.2 Gen 2 front panel connector port(s)
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)"
David689
Sorry - just remembered that I changed my case to LIAN LI LANCOOL 215 GAMING CASE before my machine was built.
David689
A quick google shows "2 x USB 3.0" on front panel
Ah, I see that in the manual now. Sorry to be thick - will that be dependent on where PCS will have plugged attached it to the motherboard? Or is it pretty certain that what it is attached to will make it USB 3.0?
