Appreciate any advice on Spec/Quote 🙏✌️
JoelGray926
Going to be using this PC to run Unreal Engine 5 primarily & film editing. Can anyone advise if components are well combined/represent value for build against cost. So very much appreciate your advice if able to provide. 🙏✌️Cheers! 👍
FRACTAL NORTH TG GAMING CASE (WHITE)
AMD Ryzen 9 9900X 12 Core CPU (4.4GHz-5.6GHz/76MB CACHE/AM5)
64GB Corsair VENGEANCE DDR5 5600MHz CL40 (2 x 32GB)
16GB GIGABYTE RADEON™ RX 7600 XT GAMING OC - 2 x HDMI, 2 x DP
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
PCS FrostFlow 200 Series High Performance CPU Cooler
ASUS XG-C100C V2 10 Gigabit PCI-E CARD (1 x RJ45)
NO RECOVERY MEDIA REQUIRED
Firefox™
Price: £1,763.00 including VAT and Delivery
Nursemorph
There's areas that need some work..the cooler will be nowhere near enough for that CPU if you are going to work it hard. Hard drive could be adjusted to a more optimum setup. For editing, NVIDIA GPUs are generally better.
What is the maximum budget we are looking at? Could you also go back to the post to forum page and include the unique configurable URL from the bottom please? Makes it easier for us to just go in and adjust rather than starting from scratch
JoelGray926
Hi, thanks for the feedback. I’ll do that asap and do some research on the things you highlighted so I understand better. My budget is £2,000 max. If I could throw more at it right now I would but I started off thinking I could get something usable for a grand! Lol Soon realised that wasn’t happening! 🤦🏻‍♂️
Nursemorph
Not sure what UE5 needs re GPU power so am going for VRAM. This will definitely need a second opinion as UE5 is out of my wheelhouse:
GIGABYTE X870 EAGLE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 32GB) KIT
16GB ZOTAC GEFORCE RTX 4060 Ti TWIN EDGE - HDMI, 3 x DP
CORSAIR 1000W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD
CORSAIR ICUE LINK TITAN 360 RX LCD RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Price: £2,067.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/9EwDpnVndW/
