Anywhere I can Optimise to reduce price
Kundrum
Ideally want to lower the price by about £100, anything I have in that's overkill? Using for gaming and Uni work and want it to last for a good amount of time, thanks in advance!
PCS SR-819 RGB FULL TOWER CASE
Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
ASUS® ROG STRIX Z390-F GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
6GB NVIDIA GEFORCE GTX 1660 Ti - HDMI, DP - GeForce GTX VR Ready!
128GB ADATA SX6000 LITE M.2 2280 (1800 MB/R, 1200 MB/W)
Intel Optane Memory
16GB INTEL® M10 OPTANE MEMORY - USE WITH MECHANICAL HDD
NOT REQUIRED
External Hard Drive
1TB Seagate Backup Plus Slim External HDD, USB 3.0, Black
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler
CoolerMaster MS110 Combo Keyboard and Mouse
Headsets
HyperX Cloud Stinger Gaming Headset
Gaming Mouse Pad
Cooler Master RGB Hard Gaming Mousepad
Cable Management
PCS 1.5M Zip Cable Tidy - Professional Cable Management
Price: £1,568.00 including VAT and Delivery
UKJLo
I think this is the AMD build (including the extras you have picked) that would probably fit best and about £100 cheaper...
PCS SR-628B RGB GAMING CASE
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
512GB INTEL® 660p M.2 NVMe PCIe SSD (upto 1500MB/sR | 1000MB/sW)
NOT REQUIRED
External Hard Drive
Headsets
Gaming Mouse Pad
Cable Management
Price: £1,473.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/czjZVQ3ZQQ/
Kundrum
I would strongly suggest and AMD build instead, the i7's are a really poor choice and AMD's equivalents will give much better performance overall at a cheaper price.
What's your max budget?
1500 preferably, can go a little higher but also wanted to make sure I wasn't overspending on unnecessary things, thanks I'll look into the AMD build
What monitor are you pairing it with, what resolution and refresh rate or make and model if you're unsure?
As an example of an AMD equivalent, with room to breathe on the GPU if the monitor would make use of it:
NOT REQUIRED
Firefox™
Price: £1,350.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/vUKnreD0hm/
Kundrum
NOT REQUIRED
Firefox™
This is the monitor I already have, so I shouldn't need a second at least for now
Kundrum
NOT REQUIRED
Firefox™
Would it be worth upgrading the motherboard to the x570-f at all or is it not much of an upgrade?
