Any thoughts on this laptop?
cg.stefan.this
Hi everyone,
I'm thinking of buying this laptop. I'm not sure yet if I take the 15,6" or the 17,3" but the Vyper seems to be my first choice.
I'm really not sure if I wait until end of July for the new AMD 4000 series to arrive (That's what PCS told me).
An other thing I'm concerned is the heat. I've read a few negative reviews regarding temperatures on PCS gaming laptops.
Vyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Vyper Series 91WH Lithium Ion Battery
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
VYPER 17 SERIES RGB BACKLIT UK KEYBOARD
Firefox™
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
Chassis
TongFang GM7MP7P (8GB RTX-2070, i7-10875H, 144Hz, Blank KB)
Price: £1,677.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/vyper-17/0m9CXS254r/
raypat
Looks good apart from the SSD. Will 512gb suffice? 2TB is the recommended these days. Hell, i installed 5 steam games and it took up 500gb.
Lemon_Haze
Hi everyone,
AC Adaptor
1 x 230W AC Adaptor
Firefox™
Notebook Mouse
Chassis
if you want you can choose recoil iv 15' inch it is also thicker with mechanical keyboard therefore should perform a bit better in cooling even if its smaller, i think vyper is 20mm and recoil 27mm thick? i would personally go with recoil IV but i do like bigger screens, dont expect them running ''cool' as those both are 8 cores cpu's, if you want you can wait for 4000 amd like pcs said but i dont think they will come with higher cards than rtx 2060, wish i am wrong but for now its not happening. anyway both are perfect option we have to wait for a review for both laptops how they perform in cooling.
cg.stefan.this
Thank you for your answers. I'm actually thinking about the Nova now. It seems like a really good machine as well. Do you think the thermals will be better despite the Desktop CPU ? Arent the temp limits lower for desktop processors ?
raypat
Sorry I don't have a link but someone has posted their nova thermals on the forum and they seem to be pretty nice.
cg.stefan.this
Yes I think I will go for the Nova. I was just wondering why the Arctic MX-4 thermal paste is available for every laptops except the Nova.
It seems a bit random ref the artic paste, my Octane VI only had the option to choose the bog standard stuff
I don't work for PCS but I would image if you phoned them after placing your order they might add in a different paste for you? It's always worth asking anyway.
cg.stefan.this
I've asked them and here is what they answered. The Nova laptop uses its own unique thermal compound solution given its configuration, along with the Octane series laptops due to them using desktop grade components in a small chassis.
I think it's time for me to order mine!
Nova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (5,400rpm)
AC Adaptor
1 x 230W AC Adaptor
Nova Series 4 Cell Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
15" NOVA SERIES UK KEYBOARD
Firefox™
Notebook Mouse
Chassis
Clevo NH55AFW (8GB RTX-2070, 144Hz N7, Blank KB)
Price: £1,597.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/nova-15/2VQhFaUVzt/
