Any Suggestions or Alterations? - Mid-range Gaming PC Spec
Khaine
Hello, I'm looking into getting a new PC that can run most games on high settings (Ark Survival Evolved / Battlefield), it'll be on a 24 inch Samsung Monitor to begin with a potential upgrade to dual monitoring in the future.
Got a budget range of up to 1200 (flexible), I was curious about whether the SSD memory size would necessary or to go down a notch, I've managed to crack down it to about this, any suggestions, alterations or if I've maybe gone overkill (likely) would be appreciated:
Case CORSAIR iCUE 220T RGB AIRFLOW MID TOWER GAMING CASE
Processor (CPU)AMD Ryzen 5 3600 Six Core CPU (3.6GHz-4.2GHz/36MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB)
Graphics Card6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive512GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
Processor CoolingPCS FrostFlow 100 RGB Series High Performance CPU Cooler (AMD)
LED Lighting50cm RGB LED Strip
Wireless/Wired NetworkingWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
Operating SystemWindows 10 Home 64 Bit - inc. Single Licence
Windows Recovery MediaWindows 10 Multi-Language Recovery Image - Supplied on USB Drive
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
DeliverySCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Total Price:
£1,155.00 including VAT and Delivery
What monitor is it you are using? Is it 1080p? That system is too powerful for a 1080p monitor. If you give a model number we can check the frequency of it to see what GPU would fit well.
Quickly:
RAM, you want 3200Mhz
GPU, between the 1650 Super and the 1660 Super depending on frequency required
Cooler, not required, go with the stock option
Wireless, select the AX200, it's far better if you need it.
Warranty, Silver would be adviseable.
Khaine
Hey thanks for the quick response,
My current monitor is actually 27 inches, basically a Tv. Samsung LT27B300 50 Hz
Honestly I'm I'd be happier with a 24 inch monitor, something akin to ASUS VG248QE 1920x1080 144Hz or even AOC G2590PX 24.5" if I could squeeze into the budget
what would be a good spec for the proposed monitors? appreciate any help as I'm a bit out of my depth on this honestly.
Either of them would be perfect and ideally suited to the 1660 Super GPU. Your current TV would be more for the 1650 Super.
