Basically trying to get a decent performance. Not anything heavyweight, mostly strategy games Civ/TW stuff .... also tried to keep the noise down with the quiet fan options.
Any tweaks that could improve for around the same price....or balance the GPU/CPU/Memory better etc etc
AMD Ryzen 5 3600XT Six Core CPU (4.5GHz/35MB CACHE/AM4)
6GB AMD RADEON™ RX 5600 XT - HDMI, DP, DX® 12
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
Monitor
AOC Q3279VWFD8 31.5" QHD Monitor - 2560 x 1440, 5MS, HDMI, DVI, DP
Headsets
Corsair HS50 Pro Stereo Gaming Headset
Standard Build - Approximately 22 to 24 working days
Welcome Book
Logo Branding
PCSpecialist Logo
Budget is "around 1300-1500" and this one comes in at 1420. FPS/Refresh rate on the monitor is not a big deal because, as I said, its mainly for strategy gaming and not FPS or other high reaction gaming.
Just really trying to see if it all "hangs together" relatively well..... and I'm not creating a car with "the engine of a ferrari but the gearbox of a Ford Fiesta" type thing. Also would be interested if its absurdly over/under specced for reasonable strategy games, with a bit of future proofing in there.
Things lie the motherboard vs cpu.... and cpu vs gpu.... and GPU to Monitor (which I understand will need 1440 ppi. Refresh rate I think goes up to about 70, but thats not so much an issue as I'm not a big FPS gamer or anything).....and also whether the memory is appropriate is the first concern.
The second might be "have I done everything I can to keep it quiet" because its going to be in the living room, and I'm trying not to create a PC that sounds like a vacuum cleaner on full blast.
Monitor
Headsets
Welcome Book
Logo Branding
PCSpecialist Logo
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
www.pcspecialist.co.uk
