mantadog
Superhero Level Poster
Well I say mechanic, I mean anyone who does work on their own car would probably be enough.
Basically something went clump, rattle rattle rattle earlier today. Tonight I managed to locate the problem, after removing all the lining in the boot i see one of the rear shocks is no longer attached. I have never done anything to any car I have ever owned before, well apart from change a wheel and charge the battery kind of stuff.
Now I only use the car for 'pleasure' at the moment so getting it fixed isn't a huge deal, but the garage doesn't have a free slot until June 3rd which is a fair while away. But it struck me im always telling people to have a dig about inside their computer when they have no idea what they're doing so I decided I can give this a go.
So after a quick google and look on youtube it seems like a relatively easy job. It looks from what I can see (haven't got it off yet) but it looks like its the rear shock top strut that's broken, anyone know if it IS an easy job? I can get the parts fairly cheap, cant really be done with paying the labour if I can do it myself... It's not a job you need loads of tools for, that's always a big thing for me as i don't have many. Also anyone know if id be as well replacing both sides and both shocks at the same time?
I await your wisdom!
