Any input would be appreciated!
Arasaki
Send In Your Own Case
ASUS® ROG STRIX X870-F GAMING WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE RGB DDR5 6000MHz CL30 (2 x 16GB)
9070XT
1TB CRUCIAL T705 GEN 5 M.2 NVMe PCIe SSD (up to 14,500MB/sR, 12,700MB/sW)
4TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
Case is going to be the be quiet Dark Base 701 Black Tempered Glass Mid PC Case, with an additional bottom fan (be quiet! 140mm Silent Wings 4 PWM Highspeed Fan).
GPU will be the 9070XT, model depends on what becomes available.
Built for gaming, probably on a 1440p UWD
My only suggestions would be:
  1. swap the 4TB 990 Pro for a 4TB Corsair MP600 Pro...as it's got much better endurance and reliability
  2. swap the 850W PSU for a 1000W PSU, otherwise you're limiting yourself to a similar level GPU down the line (and I believe 900W is the minimum recommended PSU for some 9070XT models, the PowerColor Red Devil for example)
Arasaki
I was thinking about either the XFX Quicksilver Mag.Air (+White) or the Sapphire Pure, had terrible coil whine on the last Red Devil I purchased (6900XT). Really depends on what is available through the site. Thanks for the input, I'll swap them over :)
Arasaki
Oh, and does anyone know if the RAM is EXPO enabled? From what I have read, Corsair offer XMP, and XMP and EXPO kits. There isn't anything I can see on the part picker that states if the Vengeance/Dominator kits have EXPO, and I believe the EXPO kits are typically grey in colour which doesn't match the images shown.
Edit: I might be overthinking this
It won't matter, as the motherboards support hybrid OC RAM profiles, so EXPO, XMP, DOCP (and the non-OC JEDEC of course).
