Any ideas?
johnsmith100
So my PC has been crashing recently.
Just comes up with display driver has crashed in the bottom corner of the screen.
I did a clean driver install but that didn't seem to change anything.
Specs
i5 4670
asus gtx 680 direct cuii
psu Corsair 750w builder series bronze.
Thanks.
If you try a clean installation I would suggest calling technical support for further guidance. Did you install something recently? try previous NVidia drivers?
T
TheGeeza
Do you by any chance have geforce experience installed?
I've seen quite a few PCs with similar problems that were fixed by unistalling geforce experience through a clean driver installation.
Seems to happen with the asus 680s more often. Don't know why that is.
Oliver
Hey All,
If you keep getting problems with uninstalling nvidia drivers you could use DDU (it's a 3rd party tool) have herd good things about the tool removing pesky remainders of drivers.
johnsmith100
Success! Thank you! it worked :) Will let you know if I have anymore problems.
+rep
