any final comments before i order?
chrisrs2292
yeh so this looks like it will probably be my final spec, will order it later tonight i imagine. so any final comments on it? its £1559, and dont really want to go above £1600 :)
SILVERSTONE RAVEN RV03 - GAMING ENTHUSIAST TOWER CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, CrossFireX™
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - DX® 11, 3D Vision Ready
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
chrisrs2292
i am no longer your friend :p but on a serious note, i like how it looks and its one of only few with dust filters, and definitely seems to be the easiest for cleaning :) my cats better appreciate what i'm doing to allow them to enter my room :p
on a side note - just ordered it, the waiting begins, and the praying that my pc can hang on for another week without dying completely :p
Meds
Bump the PSU up with the spare money you have. The TX650 will be pushed to run the beasty GTX580 and if you ever decide to add another it would have a heart attack. I'd look at the TX850 or the HX1000, I know the latter is pricey but they're well worth it in my opinion.
chrisrs2292
ty meds, i was considering it, just amended the order. dont think i'd be getting another 580 anytime anyway, when the time comes i'll just replace it with a single gpu again :)
