Any advice on this build? :)
tokeniko
Hi all, any and all advice would be greatly appreciated on this build I am considering.
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX***SPECIAL***
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£129)
Price: £1,651.00 including VAT and delivery.
Basically I'm looking for a good PC now with possibilities to upgrade in the future, but not keen on overclocking though.
Planning on possibly adding a second GTX 680 in the future and ram if needed.
Also, any news on availability of the GTX 680's? Would I have to wait for stock?
Many thanks :)
tom_gr7
Life Serving
looks really good mate, :)
Personally I would go for the titan fenrir cpu cooler, but to be honest this upgrade is not needed at all, I just like the look.
jonny123
Theres no need for the 1600Mhz ram (Most people dont see any performance gain and its not as stable as the 1333mhz ram as for the stock if you go on the config and just select your spec then select the fast track option and it will show you if there out of stock.
Not realy sure about the rest of build so you might need to wait for someone else but it looks good :p
tokeniko
Hi all, thanks for the replies! I decided in the end to go for this spec, just ordered it yesterday!
ASUS® P8Z77-V PRO: PCI-E 3.0 READY,WIFI, SLI, CROSSFIREX
Monitor
Just a few quick questions as its not too late to change something on the order if need be.
Are there any bottlenecks on this spec?
Any schoolboy errors/things that could be set up better?
And about the ram; stick with the Samsung 1333MHz or change back to the Kingston 1600MHz? Any real difference between the 2?
Thanks for reading and replies :))
Atuleon
^^ Congratulations. Nice rig, let us know how you get on with it once delivered. It's going to be torture waiting for it to turn up!
tom_gr7
Life Serving
you would see little difference between the two. Personally if there is little difference in price between the two, I'd go for the kingston ram, only because it looks visually better. (has a nice blue that will match ya mobo)
