JUNI0R
Hi there, before we give advice on the build we’ll need to know some info. What’s your budget? And what’s your budget for the monitor? Also are you looking for 4K 60Hz or more than that? And will you be doing anything else on the PC other than gaming? Streaming, video editing for example?For gaming, need to find a decent 4k monitor
COOLERMASTER SILENCIO S600 QUIET MID TOWER CASE
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
16GB AMD RADEON™ RX 6800 XT - HDMI, DP - DX® 12
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
NO RECOVERY MEDIA REQUIRED
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/rvrpGKXMUj/
