Antec 902
rocknroll
So the pc is now well run in and my darling two year ld managed to rip out a usb dongle on the front whilst plugged in. this has broken off the plastic inside the female connector in the case leaving the port dead.
Is there any way of replacing this????
Also can anyone recommend a good 120mm fan and where to get it for the side?
Gishank
Yes, blame your toddler, lol.
But as it's a front connector you'll most likely have to take it somewhere that deals with specialist PC repairs and have them replace it (not certain though), or repair it depending on how bad the damage is. If that's not possible you could always buy a USB splitter and use that on your other front USB port.
Gorman
You could give us a call to see if there is anything the call centre guys can do, there may be spares availiable (maybe).
