Antec 300
Clanseven
Good value, clean lines. My favourite budget case
PCS
Administrator
Staff member
We can build your system into this case using the "Choose your own case" option. Simply select this option and send us the case, we'll do the rest :)
Clanseven
My pc is being built in a Cosmos at the moment, but I just think that for the money, the Antec 300 is a very smart choice.
J
jampol
'choose your own case' customisation
I was considering the Antec 300 for its more compact size and clean lines, but if I was to update my quote (from Coolermaster CM690 MKII Advanced Case) and send PC Specialist an Antec 300 case I had purchased seperately, would there be a need or ability to customise the case to improve cooling and add some sound reduction?
I am thinking of whether would need to replace fans with quieter/more efficient ones, add sound suppressing foam panels, disk drive/psu mounts/gaskets etc.
My system quote has an overclocked intel Core i7-875K prcessor
If PC Specialist thinks it is a good idea to do this, but do not offer this as a service, is this something that I would need to attempt myself after the system was built?
PCS
Administrator
Staff member
It's not "needed" but if you "wanted" to mod your case to add sound-proofing, then you're welcome to do so after you receive your order. It's not something we offer in-house at the moment.
