As this is no longer relevant for the old thread that it was in due to the question moving from 'What case to get' to 'overall opinions on the set up' (although I suppose in a way they're the same question) I'll post my current pc plans here.
The PC is for some pretty top end gaming and I'm not concerned with overkilling parts of it as I will likely find a use for anything going 'spare'. I will not likely be upgrading or adding to this PC for a very long time which is another reason for me not minding a bit of overkill as it should, in theory, keep my PC up top for longer as system requirements for maximum performance keep increasing. Budget is roughly around 3000 Euro.
Coolermaster CM Storm Trooper
Processor
Intel Core i7 Quad Core Processor i7-4790k (4.00GHz) 8mb Cache
ASUS Maximus VII GENE: RoG, PCI-e 3.0, SATA 3.0, USB3.0
Memory
32GB Kingston Hyper-X Beast Dual DDR3 2133MHz X.M.P (4x8GM KIT)
Graphics card #1
4GB Nvidia GeForce GTX 970 - 1 DVI, mHDMI, 3 mDP - 3D Vision Ready
Graphics card #2
1st Hard Disk
480GB Kingston HyperX 3k SSD, SATA 6 gb/s (upto 540MB/sR l 450MB/sW)
4TB WD Caviar Black WD4003FZEX, STATA 6 Gb/s, 65MB Cache (7200rpm)
3rd Hard Disk
Disc Drive
16x Blu-Ray Writer Drive, 16x DVD +R/+RW
Corsair 850w RM Series Modular 80 Plus Gold, Ultra Quiet.
Cooling
Corsair H100i Hydro Series High Performance CPU Cooler
Genuine Windows 7 Professional 64 Bit w/SP1
Sound
Onboard 6 Channel (5.1) High Def Audio (as standard)
Thoughts (yes, some of this is copypasta from my old thread):
The hard discs should be nice and fast for gaming and provide me with enough storage to last me a decent while. The PSU is apparently more than required however for the small amount of extra dosh going from a 750-850w it's something I can easily do, more so as it leaves me the option to add an additional drive later on.
The blu-ray player should be nice if I want to watch anything fancy (as I frequently watch shows on my pc anyway).
The memory is overkill I know but I will likely find uses for it so I'm not too worried (and who doesn't like to say '32 gig ram' lol).
I think from what I've been able to research online that dual 970's will be better than a single 980. I may come across a bit of stutter sometimes with SLI setups that I'll need to wait to be patched away however I should always be able to just disable SLI and run a single 970 as lets be honest, even a single 970 will still blow my current GTX 275 out the water. A single 970 will still be very good at running games if I do have to disable one for a specific game so I'm not too worried.
Sound is one thing I could perhaps improve on however sound cards are one of parts where my knowledge is weakest so I'm not sure what the difference is between the onboard card and any actual slotted sound cards. I know physical cards should be better but I'm not sure is it something that's really necessary to have compared to the default option as I'm not going to be playing this in a theatre. My current pc just uses the onboard sound card and with my speakers, I've never sat there and noticed any audio distortion or quality drop at any volume.
All in all I'm fairly excited for this build as it's been about 6 years since my pc got named 'the beast' by my friends. Lately I think it's become more of 'the faithful old fella' who'll still see action as I'll be giving it over to my girlfriend but as it's still likely around a month or so before I place an order I'm still open to suggestions. Though as I've probably said a million times, I don't mind the parts of the spec that are overkilled even if they wont be of much use to me just this second as they'll perhaps become more useful over time, I hope.
Thanks for reading. What do you think?
Processor
Memory
Graphics card #1
Graphics card #2
1st Hard Disk
3rd Hard Disk
Disc Drive
Cooling
Sound
