Another New Spec
sharplucas
Ok, So I did make a spec before but I'm In need of some help well the first thing is
1.I have a 1,550 budget and I defintely want a good Mobo and a nVIDIA gTX 590.
2. In this spec I have a water cooling unit but I am not overclocking I don't know if will need the titan cooler instead.
3. I'm thinking of getting the 850w corsair but It says I only need a 750 w power supply But however it says I need 722w including A 20% allowance Please aid me on this situation!
Here is the Spec: full price £1611
NZXT PHANTOM WHITE GAMING CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
3GB NVIDIA GEFORCE GTX 590 - 2 DVI,mHDMI - 3D Vision Ready
1.5TB WD CAVIAR BLACK WD1502FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
COOLIT ECO II A.L.C (ADVANCED LIQUID COOLER) (£59)
DVI-D & HDMI Monitor Cables
1 x 2 METRE DVI-D CABLE (£5)
Quantity 1
Rakk
The Awesome
Since you're not overclocking you could drop this to the Samsung 1333MHz RAM
Again since you're not overclocking the Titan would be perfectly fine
Go for the silver warranty, it's only a fiver
The 750W will be fine for what you have, but if you feel unsure or are paranoid about it, (or plan on upgrading or getting stuff later) then you may want to think about the 850 even if it is just to give you peace of mind.
Rakk
The Awesome
but the 20% allowance what does that mean?!
It means that they've added an extra 20% to what they reckon it should be using most of the time - means that if you're power usage goes up slightly (for whatever reason) from what is expected to use you'll still be fine
PS. sharplucas, please don't post the same question twice (which I've now deleted) just because it hasn't been answered in the post following the question, it wasn't answered in that post cos it wasn't there when I started replying, so just be patient :)
sharplucas
Umm I also was thinking to downgrading to this mobo :ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
P.S Yeah I'm sorry Rakk I just am In need of help :p
