Another MSFS spec to check!
LiamK
Like so many I used to built my own PCs but looking to buy one now. Mainly for fligh simming and MSFS in particular.
Based on research so far, this is my spec
Intel® Core™ i7 12-Core Processor i7-12700K (3.6GHz) 25MB Cache
GIGABYTE Z690 UD DDR4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB PCSpecialist PRO DDR4 2666MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Corsair H60 2018 Hydro Series High Performance CPU Cooler
Any comments please.
MrWilson
Decent attempt, but could do with optimisation.
The 12700k is very hot, you’ll want a better cooler, at least a H100i to keep temps cool.
The RAM is a bit slow by modern standards, 3200mhz is definitely the sweet spot.
Not sure why you need a 4TB HDD but it will be quite slow at 5400RPM. What’s the reasoning behind that much storage?
The PSU will barely handle the 3070ti. 850W is the minimum I recommend these days and I would be leaning towards 1000W as future gen GPUs are forecast to be incredibly power hungry.
Silver warranty is also well worth it.
I wouldn't lay my hat on the Gigabyte board either, personally.
If the budget is there to allow to make the improvements to the foundation of the spec then I think the CPU/GPU combination is pretty decent. If something needs to give then I would lower the CPU to the 12600k in order to make the advised changes.
LiamK
Thanks for the replies.
While used for flight sim, I hope to storage and edit some photos and video from my DJI Mini 2.
I take your point on the 5400 v 7200 speed and have changed it to a 2TB 7200 HD.
I will change the quote to reflect the other advice as well.
Thanks all
LiamK
Revamped spec based on input
Corsair iCUE H150i RGB PRO XT Hydro Series High Performance CPU Cooler
Price: €3,043.00 including VAT and Delivery
If you pop up the unique URL from the bottom it'll allow us to go in and easily provide suggestions.
There's a "how to" in here:
Along with some other useful pointers :)
LiamK
Looking for some opinions on this spec I have put together.
Gaming but mainly MS Flight Sim 2020 and in 2nd place for photo editing in GIMP, editing RAW files 30-50Mb each.
No monitors as I have them already,
PCS PRISM TG WHITE ARGB MID TOWER CASE
Intel® Core™ i7 16-Core Processor i7-13700K (3.4GHz) 36MB Cache
1TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W)
2TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W)
Microsoft® Edge
Price: €2,740.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/intel-z690-pc/K7K3Z0NUgD/
LiamK
Back again with a new spec. Again my main interests here is Flight Sim and followed by Photo editing with GIMP.
I have 2 x 1440p monitors already.
Or should I wait for the AMD 3D V Cache CPUs to launch????
Any views?
Intel® Core™ i7 16-Core Processor i7-13700K (3.4GHz) 30MB Cache
ASUS® PRIME Z790-P (DDR5, LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 4070 Ti - HDMI, DP, LHR
2TB CORSAIR FORCE MP600 NVMe PCIe M.2 SSD (up to 4950 MB/R, 4000 MB/W)
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Standard Build - Approximately 16 to 18 working days
Price: €0.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/intel-z790-ddr5-pc/6x2vqX8M6w/
LiamK
I am in a PC-build decision dilemma.
I keep swapping between the AM5 platform (7700x or 7950x) and 13th gen (13700k or 13900k) for my new build.
I will likely pair it with a RTX 4070. Up to now all my PCs were intel but from reading different sites, the 13th Gen is 1700 pin and these m/boards could be replaced by the new Intel 14th Gen which will require a new mother board and this could be as soon as end of 2023, leaving me with no upgrade path.
While I understand the AMD5 motherboard could be around for another 2-3 years.
I intend to play games (MSFS 2020) and photo edit 50/50 time wise.
What do you think??
Liam
What do you think??
Liam
I think anyone when they mention MSFS, you'll always be recommended an AMD 7x00x3D chip, they are the best by a country mile for MSFS, while still performing well in multicore that photo editing requires.
The 5800X3D is still the current king for MSFS, not by a small margin either
But they're just about to release the new 7800X3D on April 6th, so only a few weeks away, and is expected to beat the 5800X3D by around 20% uplift
