An Unreal process has crashed: UE4-EpicGamesLauncher
Keep getting this on the laptop, tried uninstall and reinstall, happens when i log in, anyone any ideas, all drivers etc are up to date
HomerJ
seems like a problem that a few people are having by this link anyway
Yeah found that after posting here, tried it all but no joy
I see you're already on there, but worth trying this if you haven't:
"Finally I can fix it,
Just DONWLOAD the installation package from the official Epic Games website and install it in the same directory as when you first installed Epic Games, after that open the control panel → Uninstall a program → select EpicGameLauncher-> repair
both my devices run smoothly to download several games (Dakar Desert Rally & Rise Of The Tomb Raider)
Previously, when downloading games, it always crashed in the first 1-2 GB
I hope this method can also solve other problems"
Cheers @SpyderTracks just tried with no joy as it just sticks on this then
After reading through that thread further, that one I posted seemed perhaps related to another issue
It appears to be mainly affecting dual monitor setups.
If you temporarily unplug your second monitor, then do an epic games launcher repair from apps and features, then reboot and see if the errors still happen?
If they don't, then try reenabling the second monitor and see if they return.
My suspicion is that it's the toast notification pop up coming up on the secondary monitor is the cause, but something in Unreal Engine that the launcher is built on that's falling over for whatever reason.
I think it needs an update from Epic to fully resolve
Yeah that's the conclusion I've come to as well, as this is on laptop, so only the one screen, not checked it on Berserker
This looks promising from that thread:
If anyone else gets here, I couldn't get any repair or reinstall to work properly until I removed the EpicGamesLauncher folder from my AppData\Local directory. ie: delete C:\Users\yourUsernameHere\AppData\Local\EpicGamesLauncher
Then I just restarted to be safe and reinstalled, and everything worked.
Will give this a try
