An overclockable gaming PC
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5-2500k Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
4GB KINGSTON HYPER-X SPECIAL EDITION GREY - DDR3 1600MHz (2 x 2GB KIT)
1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
This spec comes to exactly £900 pounds. I am planning on overclocking to some extent so the core components are chosen with that in mind (along with the cooling). I've been browsing around these forums and people speak highly of the Caviar Black HDDs which been an influence. I have toyed with the idea of a SSD + data drive but balked at the extra cost (even opting for cheaper parts elsewhere still puts it well over my £900 bugdet).
Any input welcome!
mantadog
Superhero Level Poster
for serious overclocking you should really get the Titan as a minimum. Really you want to get some sort of watercooling. The tripple copper heatpipe will let you get some overclock out of the chip, but normaly it is recomended you get atleats the titan fenrir.
Everything else looks solid, perhaps a slightly bigger PSU to let you add in a 2nd GPU when a single card isnt quite up to it anymore?
Fear
If you are overclocking just for gaming then you are really wasteing your time as that CPU already has the GPU outclassed you would be better putting your money into a better GPU if you are wanting to improve your gaming graphics.
I see I can upgrade the cooler and the PSU to 750w for £30 or so. I'm looking for something relatively upgrade-friendly so that seems a worthwhile investment (as the budget ceiling climbs ever higher).
Here's the other side of the coin. The differences in price between the various corei5 CPUs is so much smaller compared to the difference between a 560 ti and a 570 (£76!), or a 570 to a 580 (a further £57). Of course I could just opt for one of the cheaper, locked CPUs (which I suppose would mean I could settle for a less expensive case, cooling or even motherboard). Something else to mull over, I guess.
Thanks for the comments, guys.
