cwobritton1875
Here she is! Works like a dream
Tweet with a video as well -
Id also like to know thisLooks great! How long to arrive after you ordered it?
About two weeks, it came through pretty quick as soon as I switched to a 3070 after originally spec'ing a 3080.Looks great! How long to arrive after you ordered it?
It is behind a heatsink on the bottom of the board, from the looks of it. Not sure why Asus doesn’t have both with heatsinks 🤣Yeah, I'm not actually sure where the 980 is! When I first looked inside I thought they'd forgotten to add the drive but I think it's behind the 970?
The TUF is a seriously good card, really good mosfet layout while not breaking the bank.Didn't even know you could select a TUF on the config. That's the card I'll be aiming for, only the 3080
System looks brilliant!
That's the ultimate testament!It runs Control with everything turned up to full like a hot knife through butter!
Switch the pump cap with the transparent one included in your welcome kit. It will blow your mindThis is the only one I have of the inside for now, it's tidy AF. PCS did a great job.
I wonder why they dont do that’s as standard. Like if you want rgb then you want RGB!Switch the pump cap with the transparent one included in your welcome kit. It will blow your mind
BTW, loving the build man
