This paired with Nvidia 1GB 220, 500GB HD, 4GB RAM, Will it be sufficient with 450 Dual Rail PSU?
Also, iv'e read some reviews that some motherboards don't support this CPU, an doesn't support/display/Show it as a hexacore only quad, as it needs a BIOS update before installation?
Does the Motherboard paired with this, ASUS M4A78LT-M MATX MAINBOARD recongnize it as a hexacore, an has it been tested to support it?
I'd like a answer not a, * it should work *.
Finally, is it likely, based on new hardware coming from 2011 onwards, despite VAT 2.5%increase, that this system could/would be cheaper in a couple of months? even with minimal VAT increase?
Cheers
Snowy
Cheers
Snowy
