Almost there!
KyleJones
After many posts and alot of thinking this is pretty much my final spec for my gaming pc.
Is there anything you would personally change or add to this, if so please post! thanks!
Would anyone recommend a fan controller?
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V PRO: PCI-E 3.0 READY,WIFI, SLI, CROSSFIREX
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£86)
Price: £1,316.00 including VAT and delivery.
Corfate
One little thing, you may want to change the PSU to a modular one to reduce the amount of cables :)
I have the haf-x and the fans that came with it are almost silent, I don't think you need one unless you wish to add more fans. I'd probably add one more megaflow fan on top since it only comes with one (2nd one optional).
KyleJones
Im planning on adding another 200mm fan which you suggested before :p that would be 5 fans in total for case and the cpu cooler.
Since your feedback suggest that fans are great i won't add fan controller. Im being picky atm getting it all sorted :sweatdrop:
Only other question is, if i upgrade to gtx 670 sli would my cpu need to be overclocked?
No need to OC to benefit from SLI, it would only help for benchmarking but no benefit gaming.
KyleJones
Thank you so much for your help rubensolo really have been a great help cant thank you enough :) + rep.
I order this pc within next week hopefully!
