Aerocool DS Spec advice - anyone had one?
liquidtmd
Hi - considering the below spec, with the intent to use the mesh top as opposed to the Solid / Silent one with the DS. Comes in at £858. Anything I'm particularly missing? General exp with the Aerocool case would also be appreciated.
AeroCool DS Cube Black Edition Window Mini-ITX
Intel® Core™i5 Quad Core Processor i5-4570 (3.2GHz) 6MB Cache
ASUS® H87I-PLUS: Mini-ITX, LG1150, USB 3.0, SATA 6GBs
2GB AMD RADEON™ R9 270X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
Memory - 1st Hrd Disk
1st DVD/-RAY Drive
INTEL STANDARD CPU COOLER
Office Softwar
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Quantity 1
liquidtmd
Yes - part emulation and moderate gaming. My expectations are in check with the benchmarks of the 270x in terms of FPS and resolution, my gaming won't go above 1080p. After experiencing an SSD in my laptop, the speed offered by them is pretty much essential now and I can't go back. The stock cooler of the I5-4570 has had fairly solid reviews. Most sites seems to say go with a PSU of over 500w with the 270x but the configurator on PCS actually allows a 350w PSU - so I've split the difference and gone with a 450w.
My budget is set around the £850 limit and want something nice to look at, relatively quiet and cool. I've looked at the thermals offered by the Aerocool - not unreasonable with the mesh top, although that combined with the R9-270x is something I'm curious about. Ideally I prefer the look of the Aerocool over the Bitfenix.
Is that when gaming or day to day tasks? I checked reviews when it was first released and the stock cpu cooler was not as good as a cheap air cpu cooler. I assume with a mini pc there could be slightly higher temps.
If you are not looking at very demanding games the spec looks fine, I'd personally drop the SSD to get a better gpu. It is easier to add an SSD than replace a GPU.
liquidtmd
I checked reviews when it was first released and the stock cpu cooler was not as good as a cheap air cpu cooler..
Something I'd consider - any idea if PCS offer that facility or will add that to the configurator? As the only CPU Cooling options currently revolve around the Coolermaster 120m which isn't listing as compatible with the Aerocool.
I did consider dropping the SSD and upping the GPU to a 280x - any idea how the thermals and noise of the 280x compares to the 270x, and the long term viability of it being fine in the small form chasis - all cards offered by PCS will be reference, yes?
