Hi i bought a desktop from here back in 2013 the pc for reasons which i have no idea will not recognise my 780 any more . I thought i may as well get a new build i was thinking this spec below, My budget is around £2000-£2200. I will be using for gaming and not much else. currently at 1080p but will be upgrading to a 1440p monitor by chistmas. I was just about settled on this spec below then i find out coffee lake is due for release in October. Do you think i should wait will there be a big increase in gaming performance? Also i am unsure on which case would be best suited would there be enough room and airflow with the case i have chosen. is there any other case you would recommend. any suggestions and advice would be appreciated.
CORSAIR CRYSTAL SERIES 460X RGB GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i7-7700k Quad Core (4.20GHz @ up to 4.8GHz)
ASUS® ROG STRIX Z270E GAMING: LGA1151, USB 3.1, SATA 6GB, WiFi - RGB Ready!
11GB EVGA GEFORCE GTX 1080 Ti FTW3 GAMING - DVI, HDMI, 3 x DP
1st Hard Disk
M.2 SSD Drive
256GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3100MB/R, 1400MB/W)
NOT REQUIRED
CORSAIR 750W TXm SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
FAST TRACK 5 WORKING DAY DISPATCH
Price £2,121.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z270-overclocked/ST9FCZVVt!/
Overclocked CPU
1st Hard Disk
M.2 SSD Drive
NOT REQUIRED
